Blinking Light Solved
6 posts / 0 new
WPB-TV
I know others have posted in here about resolving the "blinking green light of death" associated with Mitsubishi WS-55513 et al models, but here's another testimonial.
Had the usual symptoms. Ocassionally, TV wouldn't power up & only displayed green blinking light. Turning set off for awhile worked - for a while.
Finally, set would only display blinking gree light regardless of any actions.
Found the repair instructions (see Larry), bought the capacitors ($.39 each) and a friend did the installation last night.
Really not much to it. Removing the DM module (inside the silver cage) did require some adjustment and re-seating before it worked - but it did work.
If you haven't soldered anything in a while, it would be a good idea to practice before attempting to do the repair.
Also, keep in mind that the clearance between the top of the capacitors and the cage is tight.
Good luck!
Jim
Wellington, FL
old_tech
Hi, I have a mitsubishi VS
Hi, I have a mitsubishi VS-60719 and it has the same problem (blinking green light), I am glad that you fixed your tv set, in your post you said that you found the repair instructions and also you direct readers to see Larry, I would like to know if you can tell me how to get the repair service and how to contact Larry.  In advance I would apreciate your help.
Thank you.  Old_tech  ([email protected])
BillL
where do I get the
where do I get the information to fix my WS 48513 mitsubishi blinking light?
Bill
BillL
Info to fix blinking light on Mitsubishi WS 48513
Father Tom
I have a WS-B55 mitsubishi
I have a WS-B55 mitsubishi with the same blinking light problem.  Can you send me a diagram of the DM module?  I have a local electronics supply store and have no problem soldering.  I just need the location of the DM module and faulty capacitors.  thank you,  TK
Joyce
have a mitsubishi ws55513
have a mitsubishi ws55513 will not shut off or on with remote and have no control of sound with orwithout remote.
