I have a KP-53S35 Sony and have been reading about the ic,s. Does anyone have a service manual ? I believe I can do the work myself, and this site has been great Thank You
OK, I just downloaded the service manual from manualisland for $9.00,seems like good deal, but does not show a D board. maybe this is not going to be so easy after all. looks like STK,s are on G board.
Criscraf, no the pico fuses for the convergence are on the G board. The convergence IC's are on the D board for sure. You have to know how to read and follow a circuit diagram. Have you read the article here at techlore yet on doing this convergence repair? I will attach some links here for you to read before getting involved with this convergence repair. Good Luck.
I believe I,v read everything on this site in the last week or so. I have not yet took tv apart I looked in service manual and it has no D board and shows ic,s on G board, or I,m reading it wrong?
Your set is one of the rare ones without a "D" board, I looked up the service manual. All this means is that the main power supply and the deflection is on the same board "G", This set is an older one. Are you sure the convergence ic's are your problem ? - Can you describe the symptom.
This set uses stk 392-110 replace with stk392-180's This set also does not use all the fuses that the newer ones use, check the resistors, There maybe some fuses in the p/s but i have not looked that up yet. First if you can describe the problem, make sure this is your problem.
TV is a 1997 When you turn it on its great for about 22 minutes, then the top bows down and the bottom bows up like a bowtie and the colors seperate, the center stays fine. did I describe it right?
after leaving it off awhile it will start good again. I asumed something getting hot and shorting
It may not require new ic's since it is intermittent. Change them if you like, but it sounds like you just have bad solder connections, just simply re-solder all the pins on the convergence ic's. since it is good for a while, then you don't have blown fuse or resistors.
Ok,I'll try that,. I thought that if it worked for 20 min, that something getting hot,when it cools ok again. but what do I Know, just a contractor. Thanx
Criscraf said: Ok,I'll try that,. I thought that if it worked for 20 min, that something getting hot,when it cools ok again. but what do I Know, just a contractor. Thanx
What happens is that from the heat, the solder connection gets what is called ring cracks around the pins of the IC's. As the solder heats up, those rings of solder expand around the small pins of the IC's and they lose connections with the pins. When they cool down the rings of solder around the IC pins contract and make a connection again. Eventually if you do not repair it really soon, the IC will blow out.
Well I think you were exacly right, I got into it sunday, resoldered ic put it back together it worked about an hour till i button it up, same thing, I then touched the board and straighten up, took it apart again, just about resoldered everything, still back and forth when you touch anything on that end of board, well before it was over with cant find loose connection, but its there
Well, I replaced both ic,s, boy what a pain, trying to get lined up with holes under heat sink, anyhow eventually got them in. turned tv on and same problem if you touch board it will go good, bad,finally found a bad solder connection under center support for board,very hard to see, anyhow resoldered it and works great. I can,t thank you guys enough for all your help, it,s been an experiance.
My email is [email protected] Thank you in advance for all your help.
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
Thanx for all your help, and I,ll keep you posted
I just looked up this set also. It does not have a D board. Me bad!
you may just have bad solder connections on the ic's, try to just solder the ic's.
Larry np got your back! - Larry is a good tech!
OK, but if I remove board and check solder connections, should I just not replace IC,s anyway, the labor is taking apart and soldering, right
I agree with bad solders in the circuit.
Ok I see, I'll do that and get back to you, Again thanx for all your help
If it makes a difference, the ic on left gets warm, the ic on right gets super hot.
They both should be about the same temp. Time to replace the IC's. Probably waited and put up with the bad connections too long.
Great news man! Congrats goes out to you. Beers are on Criscraf!
