My Sony TV is used with an outside antenna (no cable) in the Toronto area on Ch 2 - Ch 57
The sound is fine on all the stations at about 1/3 volume, but on Ch 57 I have to turn the volume up to the top to just hear it.
Any thoughts
Any thoughts
Copyright © 2020
Check your sound settings, make sure you are not on sap, and that you are using just stereo not simulated surround sound. (not sure if this model has this, but that is a common complaint with simulated surround sound)
Thank you for those suggestions. I shall check them out...
