help
6 posts / 0 new
De
help
i just bought a sanyo 27 inch tv, without a manual or remote, from a tv repair shop.  my problem is that i can't get the dvd player to show on the tv.  i have a universal remote with the tv, dvd player, and the direct tv box programmed into it.  the dvd player is plugged into the av1 input in the back of the tv. i can't figure out how to get the tv to switch to the av1 input.    thanks, de
Most likely, you will need to
Most likely, you will need to get an original replacement remote because the AV switching in only on the remote on MOST of these Sanyo sets. Without a model number I can not even tell you where or who to ask for the original Sanyo remote. Good Luck
phil4607
Larry Dillon said: Most
Larry Dillon said: Most likely, you will need to get an original replacement remote because the AV switching in only on the remote on MOST of these Sanyo sets. Without a model number I can not even tell you where or who to ask for the original Sanyo remote. Good Luck
thanks for the answer.  the model number is ds27820.  If you can find out how i could get a hold of an original remote it would be great.  thanks again, de
You can always go HERE to get
You can always go HERE to get an original replacement for your TV set. If you look on the left hand side of the remote, you see an input button. That's the one you need to switch to the video inputs. Good Luck
phil4607
thanks so much, just ordered
thanks so much, just ordered the remote.  also thank you for your promptness in answering my questions.  this is a great site, i will pass it along to friends who could use your expertise.
thanks, de
Your most welcome De and
Your most welcome De and thank you so much for your compliments. There is so much more here at techlore.com then technical assistance. We have all sorts of articles on repairing, using and learning about all sorts of gadgets, and things that you would not expect. When you get the time, please explore the site and by all means leave commits or suggestions where you think we could improve or share some of your own expertise. Our goal for the members is to HAVE FUN!
