Sony KV34XBR800 7 Blinks
8 posts / 0 new
rxb
I have a Sony KV34XBR800 that I bought in 2002.  Current symptoms are no picture or sound with the standby light blinking 7 times.  From what I've researched on this forum I have the "High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits." problem.  The problem began intermittently about six months ago but stopped the set altogether shortly before Thanksgiving.  I did the power cycle routine (just tested it this morning by plugging the TV into a different outlet after it had been turned off for about a month).  After doing this latest power cycle the standby light blinked 4 times for two cycles then went back to the "usual" 7 blinks.
I have been a Sony TV "bigot" since all the one's I bought lasted anywhere from 15 - 20 years (one for 25 years!).  This one choked in a little over 5.  Not sure if that's from trying to be one of the first on my block to have a 16:9 HD TV when the first hit the streets but if this repair is expensive I'll definitely be looking anywhere BUT Sony.  They're just too expensive to be replacing or fixing every 5 years.
One other item that may be a factor is the power issues in my building.  Despite being in a 50 story tower in a major metropolitan area, occasionally the lights do "blink"indicating inconsistent power to the building that is not always weather related.  Still, I had "protected my investment" (isn't that the marketing hype?) by investing in a Monster Surge protector for the entire system which the TV has been plugged into since I brought the TV home.  Maybe I need to dig up the surge protector warranty to see what that lifetime warranty really covers.
Not being of means enough for a new TV or an expensive repair, I decided to forgo TV altogether for a high speed Web connection to see what that was like (not bad at all - the web has ENORMOUS content).  Still, I've been exploring TV replacement costs lately and now am in a position to make a fix or buy decision.  I've arranged through the Sony website for a tech visit  (feels a little like asking for the cost of an oil change through a car dealership - isn't likely the best place to go).  If the TV can be repaired at relatively low cost I'll probably do that, but was wondering if anyone had advice on 1) How do I know the technician is doing the right repair vs the most profitable one to keep repair costs reasonable and 2) What kind of cost range can I expect in a repair of this type (a high to low range)?
By the way - this forum has provided more info on the problem than 10 other sites put together.  Thanks to all for that.  Also, kudos to Larry for keeping your cool responding to some real #$%&'s, I know I would of had a wholly different response.
namath
I have been looking into that
I have been looking into that too lately.
I have a friend who's Sony is having the same issue. She didnt want to bother fixing it, so she just got a newer "better" one. I told her I was looking for a larger tv, so she offered me her "broken" one. However if it is expensive to fix I wont bother lugging that thing around, (it weighs a ton).
But I just cant seem to find how much it can cost to get it serviced anywhere!
cochita
Just an update. I did call a
Just an update. I did call a 'certified' Sony tech recommended by the mfg. Nice, competent guy who presented a $500 estimate for the fix with about $300-$350 of it in parts. I took a pass with larger LCD's going for $1K these days. Unlikely to buy a Sony again though. Now all that remains is what to do with the 300 lb paperweight in the living room.
Dwray
Replace the D Board Part #
Replace the D Board Part # A1300319A Can buy Direct from sony 1-800-488-7669
PS: this D board A1300319A is for "rxb" KV34XBR800
"Kikiera" whats the Model Number of your Set ???
namath
Sorry Dwray, I thought I
Sorry Dwray, I thought I posted that in there. Its a (sony) WEGA KV-36XBR800...Its doing the seven blink thing...which Im guessing is one of the more expensive/complicated "blinks" to fix.
Dwray
Kikiera your set does Takes
Kikiera your set does Takes the same D Board The 34 & 36 use the same D Board A1300319A Sony Lists it in Stock for $194.99
namath
Thanks so much! Im going to
Thanks so much! Im going to take it to a sony repair man then, it seems like a good price for such a nice tv...
namath
well damn, I tried to take it
well damn, I tried to take it to the listed sony repair shop...but they closed down.
Bestbuy and Sears both want to charge me a couple hundred just for diagnostics and labor...the parts will cost extra...
