MY TV DIED.
Kenneth
MY TV DIED.
       I have a philips Big screen Tv Dinasor Type. Any way it has some scematics in a folder that was taped to the back of the TV so i went through what i know it has 110 Going to the the signal panel
however it says that there should be +13 volts and one +5 volts at the customer panel from the J5 conector at the Deflecton signal panel witch i cant find . Though i did find at the 10W amp panel j406
160 volt checked with the hot ground terminal at the same plug 2 wire .
Kenneth
This is a Philips projection
This is a Philips projection TV
There is a hot ground and a
There is a hot ground and a cold ground on this TV set. When working on the power supply primary side, use the hot ground. When measuring voltages around the rest of the TV set use the cold ground like the tuner shield or the wires strapped onto the picture bell housing. A company called ptscorp.com may rebuild or exchange a defective board for you if you can determine which board is bad. Just go to the site and get their toll free telephone number. Good Luck
