To Larry Dillon or MOtvGuy or anyone who can help, I was reading the post between Larry and pnjkimbro, I have the same problem with 9 blinks with my Sony KP51WS520.I took the back off the set and I am relatively sure that the G- Board is the one on the far left. However I don't have the service manual and I have little experiance with this kind of work. It doesn't look like it would be too complicated to remove this board. Would you recomend taking this board out and taking it to a service tech and get them to replace the diodes that you refer to? How do you identify the 2 diodes in question?
On a different web site someone advised me that you can get the set to turn on by putting it in a self diagnostic mode,by pressing a sequence of buttons on the remote. This works and the set comes on and works fine except that you can't get this display of diagnostic codes to go away.Is there any way to do this? The codes are all zeros except # 9 which reads 9: ZCD 255
Thanks in advance for any help you can provide Also could you send me the service manual for this set? [email protected]
