I have been reading these forums to try and fix a problem I've been having with this TV. I realized by reading that the convergence chips were probably bad. Had those replaced and the PICO fuses on the D board checked out. Those were ok. But to no avial the picture is still the same. When looking at the Convergence adjustment screen, the crosses are way off there mark to the left and right and warped at the top and bottom. I have a picture but it looks like it should be in 3-D. When i first got this it flashed 10 times, after replacing the STK's and clearing the memory it now flashes 5 times. Any suggestions would help. If anybody has the service manual for this it would really help! You can contact me at [email protected]
the circuit is very simple, Check the two 5 amp pico fuses on "G" board.
You were absolutlely correct. I found a pico fuse that was blown. Replaced it and viola! Working again! I had been searching the wrong board for the blown fuse. Thank you zapdbf!
