I need some advice with fixing an image convergence problem on this unit. Its a 56" rear projection setup. I just paid $30 for it because I think I can fix it. I previously fixed a sony IC problem by replacing the STK's. This one has the same symptoms as my Sony TV had, only alittle more severe and with some pincusion issues as well.
I'm assuming I can simply change the STK's IC chips on this unit then work the adjustments to fix the pincusion issue. Am I on the right track, or should I pass this unit onto the scrap heap?
Any help appreciated. The service manual is dated 1997, so it seems like this might be a bit dated.
