Sony XBR Won't Turn on
Tod
I read many articles about Sony tvs not turning on, I own a KV-36XBR400 and when I turn it on the standby light blinks ten times. I know that four blinks means the fan is bad and I saw a forum article on another site saying their Sony standby light blinked seven times. Does anyone know what ten blinks stands for?
According to my service
According to my service manual for this set, there is no 10 blink code for this model. You probably have a power supply problem or a sweep deflection problem. Without making some voltage measurements, it will be hard to diagnose this TV set. If you do not have any solid state repair experience, it would be a wish thing to call in a service person to help you with this set. Good Luck
MaryK
Larry Dillon said: According
Larry Dillon said: According to my service manual for this set, there is no 10 blink code for this model. You probably have a power supply problem or a sweep deflection problem. Without making some voltage measurements, it will be hard to diagnose this TV set. If you do not have any solid state repair experience, it would be a wish thing to call in a service person to help you with this set. Good Luck
Thanks. I have very limited circuit board experience and have set up a service call. I was just looking for a diagnosis to verify with what the technician finds. Thanks for the reply.
