Toshiba 42H82
4 posts / 0 new
krutzler
Toshiba 42H82
Turned on my Toshiba 42H82 TV the other day to find doubles of everyone on screen. It is also showing mostly blue and yellow colors. The touch screen focus ends with an "error" message. The blue line in the focus mode is wavy while the others are straight. I've been reading the blogs and am seeing that I have what is possibly a convergance problem?? How do I know for sure?? Can anyone offer any assistance??? Thanks
If you cannot adjust the
If you cannot adjust the convergence with the automatic focus button, you will need to replace the convergence IC's or have someone do them for you. This is not really a hard job but you should have some printed circuit board experience and know how to solder. there also might be a resistor or two gone bad with the IC's. A repair shop will or let's say should charge you in the range of 250 to 400 bucks. Good Luck
crush
krutzler did you ever replace
krutzler did you ever replace the ic;s i have same problem now
hello i have been reading the fourms for awhile i just replaced my (Hyperboard), Hyper Module, i installed the new surface mount 10uf @ 16v electrolytic capacitors 11 of them
i have a toshibs 42h83
after i reinstalled everything now my screen looks 3d all the colors are not lining up i pressed the touch foucs button and it said touch foucs error also only getting a picture on my hi def channels all the other channels are blank
any help or suggestions thanks dave
crush
replaced ic;s and still have
replaced ic;s and still have the same problem i give up
