I have a Zenith PV5263BT Rear Projection TV. The problem is when I plug in the s-video cable to the television. I get a picture but it is mostly black and white with a very low color level. If I hook up with rca cords, it displays fine. I have tried a different cord, different satellite receiver unit, and have even unsoldered the s-video component and installed a new one. Any ideas???
You are going to need to get the schematic and trace the color signal back from the s-video connector. Probably a bad coupling capacitor, resistor or the processor IC. Not really an easy repair for the novice. You will need to use an oscilloscope to do this repair. Good Luck
You don't have a service manual for this model by chance do you?
No, I am sorry I do not. You can get one for less then 25 bucks from HERE
