I recently moved and hooked my TV up to Direct TV Satellite, I have had a predominantly green screen since that time. No matter how much I try to adjust with the normal picture settings, there is no luck. The menu on Direct TV is normally blue, yet my menu is green. Is there anything I can do to solve this problem. I am using an HDMI connection, there is a sony DVD player hooked up as component, the lamp is still good as far as I can tell. Any suggestions ?
Does the dvd playback ok, is it just the direct tv that you are having trouble with ?
Thank you for your response, I am just having problems with the direct tv, the DVD player screen colors seems ok.
