I have a 55613 rear projection mitsubishi tv that does not respond when plugged in. The green power light continously blinks. I have taken the dm board out and it does not appear that the capacitors are bulged. Does anyone have a technical manual that they could send to me @ [email protected] and have any further suggestions as to what the problem could be? I also can here a clicking sound coming from unit when plugged in.
The clicking sound is normal to happen when first plugged into the power source. Even if the capacitors are not bulged, you should replace them. I will send along to you the repair guide as well as the factor service manual. Good Luck with this repair.
Another blinking light. Glad to find some advice--the Mits tech line is worthless. Could you please also forward the instructions to replacing the capacitors.
what model number and where to? I am good but not that good, there are 5 different fixes for a lot of different models.
