kp65ws510 help needed
4 posts / 0 new
Haggerd
There was one other post for this model, but real different symptons so heres my question.  The set appears to power on then immediately power off. No picture no sound. Not sure if this helps but, after the first 3 slow flashes, the led flashes 7 quicker times. Ive had the set for just under 4 years, this is the first problem Ive experienced. Already purchased a replacement set, as was already the plan, but now id like fix and sell it, if its cost effective (and not to complicated) but first things first. I wish there was more I could say about the problems, but thats all I got. Any advice/help is appreciated.
 Hagg
zapdbf
if you want to try a quick
if you want to try a quick fix, which i don't gaurentee, because the 7 blink can be other components,
ic8002 will fail causing a 7 or 6 blink situation. it is a quick and cheep thing to try. also close to that ic is a white resistor looking device, it is a fuse. check this.
Haggerd
thanks, i'll check it out. no
thanks, i'll check it out. no idea about the on instant off deal?
zapdbf
power on and then off, is
power on and then off, is typical for a blink code situation. the micro turns off the tv again because of the fault.
