R.I.P. Dead Mistsubishi WS-55813
cf3333
Another Mitsubishi ws-55813 fall to the green light of death.  This really seems to be a major problem that will haunt Mitsu for years.  Some posts say to get your soldering gun out to save $1100.  THAT"S A JOKE!  It sounds like a bad design that they should stand behind.  What sounds better...$110 to fix my 2 year old tv, or $1100 to buy a new LCD Samsung?Frown
Rick in Arizona
I had a local Mitsubishi
I had a local Mitsubishi authorized repair facility come out and repair my WS55813 at the component level(4 blown capacitors rated at 105 C!). The total cost $240.  There is excessive heat build up in the power module. I have read and am relooking for the article on how to install a PC/CPU type of 120mm fan. Need to tap into the power supply or add an external power supply
underthetire
That was a very easy repair
That was a very easy repair to do!  I bought slightly larger and higher rated caps and replaced them. ( DM module ) i believe. About 8.00 total!
