I have a ms2730 c221 (27inch picture tube TV) that the power light flashes twice and then goes off. I tried the "demo unlock" thinking it was that and then the lights merely flashed very quickly then stopped until I pushed them again. Any ideas? No sounds from the unit itself like a voltage surge or anything like that.
Thanks in advance!
Sam
Hmmm, i don't have access to philips service manuals today, i will be back at work on friday, i will look up the code then, But i think it is a vertical stoppage, although i am not sure. It is an F8 chassis. I will have a better idea on friday.
Any luck yet Zapdbf? Sure could use some help if you have time.
Thanks again!
check 3485 near the flyback transformer if it is open, you can replace the resistor with a wire. this is per phillips as a recomend fix. so check that resistor first. Although i am offering this information freely - proceed fully at your own risk!
