There is a button on the front of the set if your tv is equipped with it, but it will only work if the convergence is off slightly if it is off allot then you need to perform a full factory convergence on it.
If both my blue and red guns can converge and the green gun is your base line.How will changing
out the stk392-110 convergence chips for the blue and red tubes, help remove the bent stripes coming out of my green gun.I have taken the covers off and looked directly in the green light and can see the stripes.I,m going to try to clean all the connections being I did get to work the first night I got.after tuneing the convergence and tuning the each color and even tuneing useig the levers on each tube it looked like it just came out of the box.The next morning when i turned it on
the green screen appeared stretched at the top 1/3 ,great in the middle third with all three crosses
white and the bottom third looks like the green electron stream was folded over on it self.
out the stk392-110 convergence chips for the blue and red tubes, help remove the bent stripes coming out of my green gun.I have taken the covers off and looked directly in the green light and can see the stripes.I,m going to try to clean all the connections being I did get it to work the first night I got.after tuneing the convergence and tuning the each color and even tuneing useig the levers on each tube it looked like it just came out of the box.The next morning when i turned it on
How do I perform a full factory convergence??
start here http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
The Green is also converged through those ic's not just red and blue.
