mitsubishi wd52627 flashing green light
5 posts / 0 new
kbman36
larry
could i trouble you for the repairs on this fine set
it sound like the capasitors might be bad as unit will only flash during a reset
please send manual or diagrams
tv repair man said blaster module was bad 899.00
thank you
MOtvGuy
First, all Mitsubishi Digital
First, all Mitsubishi Digital Projo's will flash after first turn on and when the system reset button is pressed.  That flashing indicates the set is booting up.
Second, The 627 series uses a different DM board than the models in the 525 line.
Just what exactly is a Blaster module???  That's funny.
MotvGuy is correct about the
MotvGuy is correct about the DM being different in your TV set. Never heard of a blaster module though. I do not have the service data on this model.
kbman36
after pushing the reset
after pushing the reset button the green light will flash for 60 seconds if i push the power button on the remote at the exact time the light stops flashing sometimes the tv will power up  sometimes it wont power up and one long and three short flashes of green light happen
most times i can get it on ,but remote does not work correctly
who knows , i may change all the caps just for the hell of it
kbman36
MOtvGuy said: Have you
MOtvGuy said: Have you changed the lamp on this unit?
no
repair tech said lamp was good
i have gotten tv to come on and stay on for 5hrs on wednsday
3 different times today
kbman36
