S-Video out to scart / Tv plays black and white
4 posts / 0 new
Chezze
  Hello new here, i have my comp hooked up to the Tv via the  s-video out to scart plug to my tv and all i get is black and white!  I use to have it hooked up to my Daewoo tv and it was fine, but that Tv broke so i have tried all the other Tvs in the house and none of them show in color.. Do i need a new cable? I have tried changeing setting of my Ge Force FX 5200 but nothing works... My old Tv had two Scart plug in the back .But my new Tv Philps has only one...And it aint LCD or digital just normal with a picture tube..  Any help would be nice,, what is the soulution if any...
Thanks Chezze
zapdbf
s-video has two separate
s-video has two separate signal wires the luminance(b&W) and chrominance (color component) the color component is not getting to the chrominance pin in the scart plug.
Chezze
  So what do i need to do...I
  So what do i need to do...I went and got an new cable with s-video to a special scart adapter.. the audio cables plug in to the adapter also..Bandridge.. But i still get the same result good sound but black and white still....  Help if you can ..Do i need some other cable...Some told me to uninstall the drivers and then put them back and try that... will this work??
Any help would be great
Dimitrios74
Chezze said:   So what do i
Chezze said:   So what do i need to do...I went and got an new cable with s-video to a special scart adapter.. the audio cables plug in to the adapter also..Bandridge.. But i still get the same result good sound but black and white still....  Help if you can ..Do i need some other cable...Some told me to uninstall the drivers and then put them back and try that... will this work?? Any help would be great
Hi mate, have you managed to resolve this by any chance? I am having exactly the same problems. Was working fine in my old TV, but I am now only seeing black and white with my new one (only difference is that my new one is LCD, but I supposse if you have found a solution it may work for me as well). Many thanks.
