I recently had the convergence board replaced in my Samsung HCN653WX and yesterday I turned it on and its showing black & white but the PIP is showing full color, also the perfect focus reads no sensor data when pushed what happened?
Copyright © 2020
"the perfect focus reads no sensor data when pushed what happened?" - when the board was replaced they did not save the data to the autofocus section. I have not worked on that many Samsungs, but if you have no sensor data, the tech should have saved the new convergence data. the black and white picture may be a loose plug, not sure, but if you have secondary symptoms after a repair, usually it is a missing plug. The tech should have caught all of this stuff. I would be calling the service company that fixed your tv. Sounds like they were not paying attention to what they were doing.
You may want to try www.tvrepairkits.com, they have a kit for nearly every repair and they take you step by step for the fix.
