zenith r57w46 convergence
5 posts / 0 new
tink54
hi,
the only screen i can get on my tv is the menu.  i have had rainbow wiggly lines for the whole time i have owned.  zenith sent a repairman who noted my problem and arranged for a pick up.  they kept it a month and found nothing.  i dealt with it as it would go away in a half hour or sometimes if i turned it off.  now i just get rainbow wiggles and a menu and convergence on the menu cannot be selected.  it is grayed out and the cursor skips over.  zenith says sorry warranty expired!  any ideas???
zapdbf
When the repairman picked up
When the repairman picked up the set, did he see the problem, and did they see the problem in the shop ?
tink54
the repairman saw it and
the repairman saw it and could duplicate it with cold spray.  however whe they picked it up and took it in they coud not find the problem.  as soon as it was returned it began again.
John E Johnson
Is it still intermittent?
Is it still intermittent? Sounds like loose connections on one of the convergence IC's or intermittent IC. If inspection of connections doesn't reveal something loose change the convergence IC's they are $15-30 each.
John E Johnson
