Coolant sources
trintek
Coolant sources
Figured since this is a common problem, i would try to get all the sources in one place..
A lot of times you can contact your local big screen tv repair shop and have them order coolant for you if you can not easily find a source that ships to your country..
north america
http://www.matelectronics.com/acatalog/Mat_Electronics_Chemicals___Tech_Spray...
Minimum order = 25.00 USD
http://www.prelcoparts.com/
Minimum order = 20.00 USD, click "universal tv projection tv coolant", will not ship worldwide
http://www.mcminone.com/product.asp?product_id=20-4275&catalog_name=MCMPr...
No minimum if ordered online, will not ship worldwide
overseas, uk, australia, etc
http://www.mgchemicals.com/distributors/index.html
Projection Tube Coolant #803, worldwide distributors
techspray part #1915-16SQ, crt /projection tv coolant
[email protected], techspray distributor in denmark (per techspray's support line)
this is the info i could dig up by searching and calling the manufacturers, feel free to add on to the list
Typezer0
CRT coolant change and
CRT coolant change and advanced convergence - how to
I documented the procedure I did on a Philips 55" rear projection 55p916
http://tinyurl.com/lmp6eu
CRT coolant change procedure
http://tinyurl.com/l7bd7r
basic and advanced convergence
