I have a Mitsubishi 50" VS-50SE1 which was made for Sega for several Video Games. No one has been able to find a manual for it and when Mit was contacted, they did not know anything about it. It was made in 1996. If I can find a manual, it would be a big help.
Anyway, the set comes on and I hear high voltage and it shuts down after 3 seconds. I figure the power supply is good because it turn on and the HOT is good becuase I hear high voltage. I though the Vert Output IC was bad and I changed it but no luck.
I think it may be one of the Convergence IC's is bad. I have no other ideas.
Any help or advice will be appreciated.
Kajunlion
I did a quick search, and what i am gathering it is part of a commercial video game outfit, I suspect the service manual would be part of a service pack for the whole machine. try getting the model number for the whole unit.
"I figure the power supply is good because it turn on and the HOT is good becuase I hear high voltage." --
I would not assume that, bad caps in the power supply, ect.. could cause the same type of symptom.
have an interest in old arcade games, this might be a really neat troubleshoot, if you get a manual if you want some help i would love to dive into with you.
