Hi we have a british bought PS2 and a huge boxset of region 0 DVDs (despite being advertised as region 2) that will only play in black and white - sound works fine btw. Now I presume this is because it wasn't designed to read these discs (correct me if I'm wrong) but I wondered if there's a way to override it (I heard) by getting the PS2 chipped? This boxset is 9 series and came from china so we really would like to be able to watch them.
Most likely you either have a bad S-Video cable, or the discs you're trying to read are in a different television format that what your TV is compatible with.
We have just swapped this tv to replace a smaller one and both displayed the same results with these discs, the previous tv had also had the cable swapped before. Is it possible both are not compatible with the discs? or is it more likely the discs are the problem?
Look on the discs themselves. They should indicate whether or not they are PAL or NTSC. I think that you have an incompatibility here. If you play a PAL signal into an NTSC system, you often get a picture but no color. I think it wokrs the same in the reverse. If I get a chance, I'll try a PAL signal into an NTSC system tomorrow to confirm this.
Dan
Exactly right dan. I'll also point out that Region 0 stands for "not region coded." These discs will play in any region DVD player, but the television format (PAL, NTSC, SECAM, etc) may differ from the television.
