Use internal tv speakers as part of surround
terrybarrett
Hello! I would like for the two internal speakers on my new Panasonic 42" to serve as the front L and R speakers through my JVC 7.1 amplifier. Is there a way I can use the speaker wire out of the amp and jerry rig the two leads into RCA plugs and go into the "audio in" on the rear of the tv? The reason is my wife doesn't want the additional external speakers cluttering up the tv area, and I already have the surround speakers mounted into the ceiling. I realize that the sound quality will be compromised, but compromise is essential in this situation... Thanks for any help. Terry
zapdbf
That way will damage your tv.
That way will damage your tv. Speaker level into line level can cause your tv to malfunction. Even if you could do that (which you can't) you can't get the sound you want to come out of the speakers. Unless the tv has a design element that will allow this(I have seen this on some models, consult your manual). it is not recommended by me.
