Hi,
I have a Philips 60" and the manual color converge is no longer working for either red or blue. The picture is distorted/curved and red is bleeding in. Does this mean I need a new convergence board or could this be a more simple problem? Thanks!
It is most likely the convergence ic's very common problem. On this board you will find allot of tips about this, your ic's will be similar it will be stk392-??? and all the posts regarding this should fit your problem as well.
I have this same problem probably. What can I do? looks like red lines in bottom left corner of tv. Tv looks a little distorted also. Help please. Thanks
i have the same problem. we were watching it and it shut itself off then took a minute or two to come back on. when it did the red is bleeding thru. i can manual converge the blue and the red moves side to side but won't move up or down. can anyone help? i've ordered a new 65" so if i can't fix my 60" fairly cheap i'm going to sell it for parts for someone to fix. thanks in advance
