The cables come off on the distribution block side, you push down and twist. sometimes they can be stubborn. don't try to remove from the flyback side.
If you have a direct view tube television, you need to take a screwdriver and attach it to the dag ground with a jumper wire, it will be a braded wire strap around the back of the picture tube. then push the screwdriver under the hv cap so it will discharge. Then remove the cap by pulling sideways then up at an angle.
