i HAVE A SNES AND THE PICTURE IS ALL FUZZY. i DONT HAVE AN AERIAL SWITCH BOX AND THE AERIAL CABLE RUNS FROM THE TV TO THE GAME. tHE CABLE IS NOT THE BEST. cAN THIS BE THE CABLE OR SOMETHING ELSE?
it's most likely a poor or loose connection if you're using an RF cable. Jiggle the RF wire on the back of the TV and see if it cuts in and out.
The easy fix would be to ditch your RF connection. Head over to gamestop and pick up a used composite/S-vid line level cable for the N64 (it'll work with your SNES and they probably have a few left). Will solve your problem and also give you a better picture from your SNES.
Cheers! And happy Classic Gaming!
Question: What SNES games are you playing. I'm a bit of a retro gamer myself. :-)
