KV32HS500
BRIM
KV32HS500
I HAVE A KV32HS500 WITH THE SYMPTOM OF 6 BLINKS BY THE STBY BUTTON. FROM ALL
NDICATIONS THAT IS CAUSED BY THE JUNGLE IC AND THE C515 AND 516.  CAN YOU TELL ME WHERE
THOSE PARTS ARE LOCATED AND DO YOU SUGGEST I REPACE THE ENTIRE PCB INSTEAD OF THE
RESPECTIVE COMPONENT. DO YOU HAVE A COPY OF THE SCHEMATIC OF THAT TV.
 THANKS
BRIM
zapdbf
6 blinks can be many things,
6 blinks can be many things, don't blindly think that will fix your television. Sony's are one of the more complex televisions to work on. If you don't have any experience soldering, then maybe board replacement is best. 6 blinks could be "D" board, but it could be other things as well. these boards are expensive, and you don't want to get it wrong.
