I have a mit. model vs-60707. I have a convergence problem. i replaced the ICs' STK 392-110. It worked for one day then failed. I replaced it again, but only worked for only three minutes then failed again. desperate for help!!!!!!!!!!!!
Copyright © 2020
Repat failure of the stk's can be because they are over compencating for crt's that have a bad static centering. Also if you use stk392-150 or stk392-180 they are better(higher wattage), but don't buy the realy cheap ic's because they will also cause repeat failures. The cheep ic's could be factory rejects and are not up to the task. Try MCM electroinics.
