Hello to ALL,
Am new here and I need help so BAD.
I needed the part numbers for FETS Q8013 and Q8014 and REGULATOR IC8005. I checked this and found BAD, but someone accidentally throw it away before I can write down the part numbers.
For references. TV blinks 10 times
I will appreciate a lot if someone can give me the part number for these components
the model again is KP-51WS520 and this can be found on D Board.
thanks in advance
Check r8051 here are the part numbers
q8013 = 6-550-882-01 gen(2sk3568)
q8014 = same as q8013
ic8005 = 8-759-586-17 gen(tl1431cz-ap)
r8051 = 1-202-933-61 fusable .1 ohm 1/2 watt
thanks bro... thats helps me a lot... ur greeeat!
Hi again,
I've fixed the TV (thanks to you) and worked fine for a week or so and now another problem occur, it was intermient for a few days, 9 blinks this time, and sometime 5 blinks. Now it is stuck to 9 blinks. the tv powe up(sort of), there is a raster (no picture) but wont respond to any control (vol, ch) except for power. Once it start you can not turn it off, it pressing power button will shotdown the raster fora while then it will come back on but still doesnt respond to controls.
I went thru some if the posting and found out that D6116 and D6301. I needed your expertise again. one of the diode is SMD and i cant figure out the value. kindly again give me the value of these two diode D6116 and D6301 of the G board.
Also, do anyone have any other tips to fix the problem i have.
thanks again.
