1639 posts / 0 new
Danr7467
I have a WS 48513 with the
I have a WS 48513 with the infamous blinking light can you please send me the instructions and guide to fix it [email protected]
D1969
I would love to help whomever
I would love to help whomever I can, although, I am not a tv repair person. I was able to gather information from this site and put it to use. I have the WS-65713 and am unsure if the other models are identical or not. I would recommend beginning at the first post on this concern and read through them all, I spent a couple hours reading and came up with a very useful repair. Larry Dillion is the master behind all of this, his info was the most helpful.
juliet
hello Larry,
hello Larry,
i have a mit ws-65513 and it suddenly started with the blinking light problem. it won't turn on. could you please send me the service manual and the repair instructions please....please.... thanks a lot.
Juliet.
mfk68
Based on all the post, you are the man! Can you also send me the same instructions you are sending to the other folks? I have the blinking light issue on the WS-65813. Thanks!
greg000
The green light on my WS
The green light on my WS-65813 is blinking also.
Can I please get the instructions to fix it?
RanMic
Larry and Riley
Larry and Riley
We also have the blinking light problem on our 4 yr old WS65513. Could you
send instructions on how to repair it. We also bought the 5yr warranty.
PaulS
I've bought Mitsubishi WS-65613 4 years ago from Sear and recently my TV Timer started blinking green this morning and does not stop blinking and I cannot turn it on.
Would you please send me the instructions and service manuals to fix this blinking green light problem. I've had this blinking green light problem before but it would stop blinking after blinking for a long time (5min to 1/2 hour). This morning it started blinking again but doesn't stop.
Are there any precautions one must take to attempt such a repair other than simply unplugging the unit. I'm sure I can solder the new caps.
Please send me either a diagram or pics of the location of the capacitors that I need to replace?? to: [email protected]
Paul
PaulS
I've I have a WS-65809 and the same blinking light problem. Would you please sent me a copy of the repair instructions as well diagram or pics of the location of the capacitors that I need to replace?? via email: [email protected]
Million Thanks,
Khmer
Natedog300
I have a WS-55513 and the same blinking light problem. Will this work for this model.If so can you please sent me a copy of the repair instructions as well diagram and pics of the location of the capacitors that I need to replace.
angelfci
Hi there!
Hi there!
I am so thankful I found this site! I love my 65813! A three year old set that cost so much should not be breaking down this way. But no I have the same blinking green light issue. Please send me the repair instructions to [email protected].
Thank you so very much!
Angel
Lawnie
I have a WS-WS65813 and the
I have a WS-WS65813 and the same blinking light problem. Please send me a copy of the repair instructions, diagram and pics of the location of the capacitors that I need to replace. Thanks!!! I will let you know of my progress on the repair.
Arron2165
Hello,
Hello,
I have a Mitsubishi WS65517 on the fritz. I am staioned in Germany and have had the tv on a converter for the past two years. We make it a habbit to turn off the converter when we are not watching tv. Recently when we turn on the converter the green timer light blinks several times and when it stops I am unable to turn the tv on. My first question is do you have any suggestions on how to fix it and second, Is there any way to convert the tv to dual voltage. Thanks, Arron
Lawnie
I have a WS-65813 and the
I have a WS-65813 and the same blinking light problem. Please sent me a copy of the repair instructions as well diagram and pics of the location of the capacitors that I need to replace. Thanks much in advance.
Lawnie
I just sent a message to
I just sent a message to please also send me the instructions and pics to repair the blinking light problem on my WS-65813. I forgot to include my email address. It is [email protected]. The first character is a small "L", not a numeral "1". Thanks again.
Myles Long
Help!
Help!
I can really use the fix info. for the green blinking light problem. Can you send it to Myles. My email is [email protected]
Dennis3281
I have the same problem Mitsubishi WS 55 859 with built in HD tuner. Fast flashing light no power up. It sounds like the DM cap issue. could you please send me the repair information?
Thank you very very much
Best Regards,
Dennis
str82thetop
need help with replacing the
need help with replacing the caps on the dm board and the rapair manual instructions, larry or anyone's help would greatly be appreciated. model number WS-65813
THANK YOU
MY E-MAIL IS   [email protected] thanks in advance
alfredt2001
I'm having the same blinking green light on my
Mitsubishi WS-65813. I noticed you helped people
with this issue for over a year now. I'm sorry to
bother you but could you help one more person please.
Could you send me the documents to change the 4 cap
to fix the tv.
I will greatly appreciated.
My e-mail is
Thanks, hope to hear from you soon.
Alfred.
Anthony 7
Green blinking light too :(
Green blinking light too :( (ws 48613)
please send info to [email protected]
Thanks in advance!!
Hennessey
Hey Larry, I Have seen that
Hey Larry, I Have seen that you have helped a lot of people here with the same problem I now have. My model is the mitsubishi WS-65869, and I would really appreciate it if you could email me the instructions that you have to fix this blinking green timer light. my email is [email protected]
ecastro
Hello Larry... wow... have
Hello Larry... wow... have been reading all these posts. Same problem with my WS65813. Please also forward that info my way. I just got this tv from a friend. Is it really that easy to DIY.
We should all send you a dollar for sending all of us the instructions.
RIFE
Has anybody received the info
Has anybody received the info from Larry, I don't think he has been answering these messages. I have model WS55909 and was able to find his directions for replacing the IC by searching under his name and looking at posts from him, however I am unable to find the directions for replacing the capacitors in the DM. does anybody have any answers? If so please e-mail me at [email protected].
D1969
I don't think Larry is
I don't think Larry is available any longer on here, however, I am happy to pass along the info I have and written on the WS-65713 and it worked great. Have heard a couple success stories along the way. Good luck all. Also, it is imperative to leave an e-mail address to send info to. You can also reach me at [email protected]. Merry Christmas all !!!
Hogan Again
We all hope that Larry is
We all hope that Larry is still feeling well. But until we hear from him again, here's a few alternatives:
  • For easy to follow instructions and pictures, visit this forum:
http://hdtvoice.com/voice/showthread.php?t=32186&page=1&pp=20
Hopefully, one or both of these will answer your questions.
Good luck,
-- Hogan
Sean23
My Mitsubishi WS-65813 just
My Mitsubishi WS-65813 just fell victim to the blinking green light issue as well. Larry, you seem to be the man, can you please send me the documents on how to fix this ([email protected]).
Frank3001
Can I get the info on
Can I get the info on locating the Caps in my WS-65813 TV to fix the blinking light.
D1969
Jim, need E-mail address to
Jim, need E-mail address to deliver it. LOL
Warhawk
Hi, a few days ago, I got the
Hi, a few days ago, I got the blinking light problem on my three year old WS55513 TV. Could you please send me the instructions on how to fix it to [email protected]
Thank you very much.
Kevin
Frank3001
Anyone have a PIC to show
Anyone have a PIC to show where the caps are on the WS-65813?
Hogan Again
Here's another step-by-step
Here's another step-by-step instructions with photos for fixing your Mitsubishi "Green Blinking Light" problem:
Good luck.
 -- Hogan Again
