1639 posts / 0 new
Larry Dillon's picture
they should be their in your
they should be their in your hands before the morning sun. Good Luck
riley96
riley96's picture
Larry Dillon said: Ryan, I
Larry Dillon said: Ryan, I have sent you the info for your TV set. If I am not mistaking, your model of TV set has only 4 capacitors in the DM board. Read everything I sent top you and compare. Good Luck
Hi Larry...I have the same issue with a WS 65613. You are doing everyone a great service! Thanks so much!!!!
riley96
riley96's picture
riley96 said: Larry Dillon
Sorry you need an [email protected] again
riley96, they should be there
riley96, they should be there by now. Good Luck
Smash8ball
Smash8ball's picture
I am having the blinking
I am having the blinking green light problem on my WS-65713. Can you please send me all the info I need to fix this problem? I hope it is easy because I am not very electronic component smart. Thank you Larry.  Email: [email protected]
-Brandon
Brandon, try to find someone
Brandon, try to find someone who can solder, or pay an expert to do it cause you have one chance to save this board. If you damage the printed circuit, you will have to buy a very expensive board, i am sending you the info. Good Luck
Blackhawk
Blackhawk's picture
Larry:
Larry:
I have a WS-65813.  I think a tech. replaced the caps while it was still under warantee.  I would like to replace them just to see if this cheap repair does the trick.  If it doesn't work I think it will be time to upgrade to new technology.
 Could you please send me the instructions on the cap replacement?
Many thanks
Ken
Blackhawk
Blackhawk's picture
Larry:
Larry:
I forgot to give you my email.
Ken
wrwelect
wrwelect's picture
Larry, I am having the same
Larry, I am having the same blinking green light issue with my WS55613 Mitsubishi. Can you send me the info you have been providing the others on this forum regarding the caps? Thanks, Duane
Larry not sure if you missed my original post but I have not received the info yet.
Rick Sykes
Rick Sykes's picture
Larry, looks like I am having
Larry, looks like I am having the same blinking light problem with my WS-65813.  However, this is at least the third time but previous to this time I have been able to eventually reslove the problem by simply unplugging set several times or holding down the power button.  Set would then work great for 7 or 8 months before problem would happen again.  Any ideas on what that was all about? Regardless could you please send me the cap replacement info.
Rick
thedad
thedad's picture
Me too!
Same problems - need drawings and please define: DM Module.  What does it mean?
My Model number is WS-48613
Thanks!  (In advance!)
thedad
mwonger1
mwonger1's picture
Hello everyone, I have a
Hello everyone, I have a WS65813 and I have the same problem. I was wondering if someone has already gotten the manual and directions for replacing the DM caps from larry? Or if Larry you could send this info to me. Thanks all Mike. [email protected]
I will be sending the service
I will be sending the service information out to you all soon, on the next mailing. Good Luck
Danno
Danno's picture
Just to let everyone know.  I
Just to let everyone know.  I have a WS-65813.  It had the blinking green light DM issue.  I removed the DM Module, replaced the four caps and re-installed the board only.  I did NOT re-insert the board back into the cage out of which it came.  I just made sure that the copper fingers that were at one time touching the side of the cage did not touch the board.  I did this by bending the one on the left side so that it pointed straight up.  The TV works GREAT!
The metal case is on the
The metal case is on the board for a reason. Yes it may work now, but you may get interference without it at one point. You really should reinstall the case. That's my pro opinion. Sealed
joseo1946
joseo1946's picture
Larry Dillon said: cantaim, I
Larry Dillon said: cantaim, I have sent you the documents. Make sure the board is seated well into the board below the DM board. Also read the article, it explains about some small surface mounted fuses that go bad sometimes also. Good Luck
I have the same blinking green light with my WS-65713.  Do you have a service manual and/or repair instructions on how to replace the four capacitors?  This seems to be a problem to all these Mitsubishi projection TVs.  I would appreciate any help you can provide.  Thanks in advance.  My email is [email protected].
 Jose
jagxprt
jagxprt's picture
Larry Dillon said: Speed, You
Larry Dillon said: Speed, You will need to contact an authorized Mitsubishi parts house and ask them, as the manual does not even have a schematic or parts list for the DM board, only a part number for the entire board. I have never replaced the eeprom board in one of these TV sets. If the Caps do not fix the problem, I'm afraid the only option is to replace the DM. Good Luck
Larry:  I am a pending new member, having found you today when searching for help related to my green light blinking on Mitsubishi WS-65813 - was told that it was not repairable, but that I needed to get the DM Board replaced for big money.  Your information seems to imply that we could get the DM Board functioning by replacing the CAPS.   Do you have instructions to email me to assist in that repair process?  Obviously if I can fix it that way, I win....
David Russomano    [email protected]
Jagxprt and Jose, I will get
Jagxprt and Jose, I will get those documents you need, INCLUDING the free factory service manual out to you tonight. Good luck with this repair.
Larry
champ333
champ333's picture
I've got a WS-65813 with the
I've got a WS-65813 with the same problem..please send copy of repair...thank  you..  [email protected]
Champ I just sent out the
Champ I just sent out the info you need for your TV set. Good Luck
Welfl
Welfl's picture
Have the continuous blinking light for Model No. WS-55613.  Can you send the repair instructions for the dm board to [email protected]?  Thanks!
Sure man, I am sending the
Sure man, I am sending the documents out in just a little bit tonight. Good Luck with this repair!
dabull
dabull's picture
Larry Dillon said: I am
Larry Dillon said: I am sending you the documents you requested, Good Luck
Can you please send me the documents? I have a WS-65813 model with a blinking green light to which the reset button does nothing for. [email protected]
They are on there way dabull!
They are on there way dabull! Good Luck with the repair!!
Stallworth
Stallworth's picture
Larry Dillon said: They are
Larry Dillon said: They are on there way dabull! Good Luck with the repair!!
You sound like a lifesaver!!  Can you please send me the documents as well? I have a WS-65613 model with a blinking green light to which the reset button does nothing for.  My e-mail is:  [email protected].
Thank you!!!
SS
They are on there way ss.
They are on there way ss. Good Luck with this repair.
She*Devil
She*Devil's picture
Hello Larry,
Hello Larry,
Like all the others I'm having the green blinking light problem.  The first few times it came back to life, the last time it took hours for the light to stop blinking but it did come back, now it just continues blinking.  I have model # WS-65613.  If you would please send me any information on how to fix this problem, and/or the service manual, I would appreciate it very much.  My email is [email protected]
Thanks!  :)
Nice Picture She*devil. I am
Nice Picture She*devil. I am mailing out the documents you requested along with the service manual. Good luck with the repair.
Capt Steve-O
Capt Steve-O's picture
 I too suffer from the dreaed flashing green light.  I have a WS-65813.  Could you send the repair info to [email protected]?
Also, I've seen a couple of possible causes on this (power surge, overheat, age)... is there a definite cause or can this just happen randomly.  I just moved the TV to another part of the house and this happened shortly after.  I would like to take any needed precautions to avoid it in the future.
Appreciate your help... with such a widespread problem, I would think Mitsu would come up with a better and cheaper fix.  The repairmen must love the business though!
siidman
siidman's picture
Larry, I have a WS-55513 and
Larry, I have a WS-55513 and the same green blinking light problem.  Could you send me a copy of the repair insructions and the diagram. My e-mail adress is [email protected].  Thanks,  siidman
