TV won't turn on and keeps flashing 9 code. By the forum, the G board is bad, how do you identify that board? The forum/Larry says the diodes d6116 and d6103 are bad how do we locate them on the board? Also, since this fault occurred - when the TV sometimes will turn on, the left side of screen is green, center is blue, and right side is green.....what's causing that?
That is for projection TV sets I'm afraid. These codes are so different for the projection TV sets, the LCD TV sets and then for the tube type set like you have. If I am not mistaking, as I do not have the service manual fro your TV set, The problem your having could very well be a diode on the GA board, but I am not sure of the diode number. The other problem your having sound very much like a degaussing problem. Could be a simple bad connection on the printed circuit board. It very well could also be causing the 9 blink problem unless one of the problems you have been living with and now the repairs are piling up. This is probable that you will need to have this set look at by a pro. Good Luck
