I have a sony KP51WS510 i removed all connections on the D-board but i can not after numerous tries remove the larger red high voltage cable that connects in the Flyback transformer. THis transfromer has two cable one large one small, the small one i read on other post that comes pull out to a bare end, the larger one is to be twisted 90 degress and it will pop out according to service manual, but it does not. i have twisted it clock wise and counter and nothing. My hands are killing me, this is all i need to remove the d-board. please help.
The hardest part was removing the HV cables from the D Board flyback tranformer. I twisted and turned, twisted and turned and eventually removed the focus ca
No where in the 510 service manual do i see where to remove the red cable from the flyback, as I have never had to remove it. I have though removed the D board by disconnecting the wire from the flyback at the distribution block. Some Sony's do at the fly, some do not. If you have a page number, please share with me?
I got it came off from the distribution block, Also i called Sony and they reffered me to another number which handles, their product that are sent in for repair, The lady on the phone said someone will call me within 24-48 hours but the cost shoudl be around $54., The other option is Tristate at $140. I will update you on the call from Sony. Also how do you check Pico fuses on Gboard? Thank you
Just measure across them. They should measure a dead short just like a fuse.
