mitsubishi ws55511 green picture shadowing
11 posts / 0 new
surferjp
Hello everyone.  I am new to this forum, and would like help trouble shooting a picture problem.  I have a two inch green shadow on the right side of all images.  I have tried using the convergence to correct the image problem, but my problem is this the red convergence moves both vertically and horizontally, while the blue cone will move up and down, but not left and right.
 Has anyone experienced this.  If I correct this blue convergence issue will the picture imaging resolve.  I am realitively competent with most simple electronics, is this issue beyond my troubleshooting or intermediate electrical skill set.
 Thanks in advance for all of your help, Jeff
It is about intermediate
It is about intermediate skill level I would say. You have a bad convergence IC's in the TV set, or it is on its way out. It is a single IC that controls all six channels of the convergence correction. It is labeled STK 393-110. You can get an original replacement from HERE You only need one of them. I know you can find these a lot less on line, but they will most likely be manufacturers rejects or after market China stuff, and we know how the China made stuff has been lately. Good Luck
surferjp
Thanks Larry,
Thanks Larry,
How do i know which one is bad?  Do I just order two and replace both.  Are they soldered on to the board.  Can I use an ohm meter to check them out?  Are they in the front or back of the set. Do you have a service manual in pdf form that shows location.
Thanks again, Jeff
This set only has one IC. Do
This set only has one IC. Do you have an e-mail address?
surferjp
Yes email is surferjp
Yes email is [email protected],  Thanks Jeff
twmackey
I have some what of the same
I have some what of the same problem, I had a power flucuation on the 23 and today when I turned on my  mitsubishi ws55511 tv I saw a vertical green line on the left side of the tV. Could some possible give me a soulution
Thank you
Tom
We will need a little more
We will need a little more information Tom. You saidd you saw a line. Is the line still there? Was there a picture or sound? Is there anything else on the screen? Have you tried to reset the set yet?
Jeff, I missed your return
Jeff, I missed your return post. I just sent out that service manual you requested. Good Luck and Happy New Years to you and yours.
twmackey
There are Green Red vertical
There are Green Red vertical lines on the Left side of the TV. I have never had a problem with this TV in the 5 years that I have owned it. Yes the lines are still there. I havwe picture and sound. When I was watching a black and white movie you can see the charictors out lined in yellow. I also unplug the tv for 20 minutes as well. Still have the vertical lines. Tom
Tom, the convergence IC needs
Tom, the convergence IC needs to be replace and the IC replacement will involve soldering. Look at this post in the beginning, as it will tell you where to get the IC from. If you do not have any soldering or printed circuit board experience, play it safe and call in an authorized Mitsubishi repair shop to assist you in this repair. Good Luck and Happy New Year.
twmackey
Larry Dillon said: Tom, the
Larry Dillon said: Tom, the convergence IC needs to be replace and the IC replacement will involve soldering. Look at this post in the beginning, as it will tell you where to get the IC from. If you do not have any soldering or printed circuit board experience, play it safe and call in an authorized Mitsubishi repair shop to assist you in this repair. Good Luck and Happy New Year.
Iwent ahead and bit the bullit and called a repairman. He siad it would be about 450.00 He said he was suprised it lasted that long. He says he does alot of them and they only last about 3 years They generate so much heat.   My brother could of done the work but he lived out oif town and I need my tv now.
Thanks for the post.
 Tom
