About 6 months ago i started having trouble buring dvds, i was using a liton dvd burner,after about 150 dvds, it would burn about 23 percent, and i would get a burn error. I bought another brand new liton dvd drive,and it did the same thing. I was told to get the firmware updated, i did it did no good. I replaced this drive with a new sony dvd drive. It worked fine for about 1 month. Now it is taking 3 times as long to burn dvds as it once did. It is getting slower and slower. MY other programs seem to be working fine. i have 2 dvd burning programs, nero, and 1 click copy, and both have slowed down a lot, i have only burned about 40 dvds on this drive. don
Hi donaldbst,
I did respond to your similar question over here: http://www.techlore.com/forum/thread/...
I do really think you're having DMA issues (stands for Direct Memory Access). Did you check out your current DMA settings using the instructions I posted?
If my hunch is correct, the easy fix is to download DVDFab HD Decrypter (free version), and there's a button in the settings area to reset DMA. Do that and restart the PC. Hopefully it will get you all fixed up.
matt, i downloaded dvdfab, as you instructed, also i am using norton 360, i cleaned cookies up in temp files, and registy. it is working fine now. it is burning dvds in about 10 minutes. Can i use this same program again to reset the dma if it occurs again? thanks very much. don
