HELP FOR MY ORION TV
5 posts / 0 new
CBITZER28
I HAVE A ORION TV ITS A 32 INCH I THINK TV/VCR COMBO (OLDER). FOR SOME REASON ON THE MENU OPTION IT SKIPS OVER THE (CH SET UP) AND IT WILL NOT LET ME CHOOSE THAT OPTION TO CHANGE TV TO CABLE OR PROGRAM CHANEELS...CAN ANYONE HELP?
Please refrain from posting
Please refrain from posting in all CAPS. It's considered rude in most fourms.
As for your problem, you should be in tuner mode to change tuner settings. If you're on an external input the option may not be presented to you. Give that a go and post back.
CBITZER28
Sorry I use caps while typing
Sorry I use caps while typing dr's notes at work..caps are a habit.
ok you lost me on the tuner mode, there is not a button for that mode, any ideas on how to change modes?
frep420
When you are on input 1 or
When you are on input 1 or video 1 or anything like that, the tuner settings are unavailable because you are bypassing the tuner at the time. press ch up or enter a channel number, then go into the menu.
Hi frep420,
Hi frep420,
Great advice, and absolutely spot on!
CBITZER28, did frep420's advice get you going?
