I have a JVC KD-322 / KD-G321 Not quite sure which one is mine. My problem is that every time I turn off the Receiver, Or turn off the engine, it always goes back to the first song when it plays again. In the manual it says that it will start playing where it stopped, Can you help to solve this problem. Is something wrong with it. The CD player I had car before use to start playing where I Turned it off, cant understand why this one wont.
Need Help With JVC KD-322 / KD-G321
Fri, 09/14/2007 - 18:49
sounds like you are turning off the main power supply to the unit,, usually there are 2 power supplies one is switched and one is permanent, if you turn off the permanent power then you lose all your settings,, check the wiring , and make sure you have a permanent supply ( not through the ignition )
hope this helps,,
