when turning on my vehicle the woofers i have wired to my P3001 seem to pull or suck all the way back and this is with the volume all the way down. nor will the speakers move from this backward position until the vehicle is turned off and then they are released and move up to the normal position that they usually reside in when every thing is turned off. i tried changing the negative and positive around and then turning the vehicle on, only instead of being sucked all the way back they instead move the oppisite direction, pushed all the way forward as far as the foam ring will allow.
your help and any suggestions are greatly appreciated
