tv
4 posts / 0 new
Lil J
tv
my tv is showing a purple dot on the right corner it's not a speaker there wasn't one so can u help me out
It's a Emerson it been doing it for like a month are so and it's about 4 yrs old and when hit it go away but it come back again and no there wasn't a power surge
We will need a little more
We will need a little more info to help you. What type and brand of TV set is this. How old is this TV set. Did this just apear, or was the set bumped or moved? Was there a power surge lately?
Lil J
Larry Dillon said: We will
Larry Dillon said: We will need a little more info to help you. What type and brand of TV set is this. How old is this TV set. Did this just apear, or was the set bumped or moved? Was there a power surge lately?
It is a common problem with
It is a common problem with solid state TV sets. There is a bad connection in the degaussing circuit that needs to be re soldered. The more you hit the set, the more of a chance you will not be able to have the set repaired soon. This is not a job for a novice. Call in a pro to resolder this bad connection before it gets bad and burns the board. Good Luck
