Would you please kindly send a service manual to me for my TV set:
Sony Wide Screen Model KP-57WS510
My E-mail address is [email protected]
Thanks.
My TV has a same problem as you have answered before. The project TV suddenly went into convergence problem. Every object on screen gives 3 colour shadows. The lines on screen are not straight and look like a dumbbell horizontally.
If it is possible, would you please let me know the parts name from following form?
It comes from http://www3.sears.com/
Model PROTECTION TV - KP-57WS510 (Page 1) Copyright © 2020
Part Description
Part
NumberDiagram
Reference
NumberQuantity
CRT 07MRC21 (GREEN), SER#8000001-80XXXXX AND 90000001-90XXXXX
873518205
(NI)
CRT 07MRC41 (BLUE), SER#8000001-80XXXXX AND 9000001-90XXXXX
873518705
(NI)
CRT 07MRC41 (RED), SER# 8000001-80XXXXX AND 9000001-90XXXXX
873518805
(NI)
COUPLER (GREEN) ASSEMBLY, CRT, SER8700001-87XXXXX AND 9700001-98XXXXX
A1604483A
(NI)
COUPLER (RED) ASSEMBLY, CRT, SER#8700001-87XXXXX AND 9700001-98XXXXX
A1604491A
(NI)
COUPLER (BLUE) ASSEMBLY, CRT, SER#8700001-87XXXXX AND 9700001-98XXXXX
A1604493A
(NI)
BEZEL ASY
X40407962
1
EMBLEM
438107901
2
SCREEN CONTRAST
409088111
3
PLATE, LENT
408194911
4
PLATE, FRESNEL
408195011
5
HOLDER, SCREEN
408456812
6
SR BRD, MOUNTED
A1400759A
7
HOLDER, SCREEN
408456802
8
HOLDER L, MIRRIR SIDE
408346201
9
HOLDER, MIRROR
408150101
10
HOLDER R, MIRROR SIDE
408346101
11
MIRROR
408456102
12
COVER ASY, MIRROR
X40398241
14
BOARD, REAR
409088301
15
CABINET ASY, BOTTOM
X40417841
16
CASTER
404075501
17
FOOT
407502001
18
BOARD, FRONT
408456601
19
H2 BRD, MOUNTED
A1405147A
20
BUTTON
408228401
21
H BOARD, MOUNTED
A1405148A
22
BUTTON POWER
409432601
23
GUIDE, LED
408373301
24
H4 BRD, MOUNTED
A1405149A
25
GRILLE, SPKR ASY
X40417831
26
DOOR
409432301
27
CATCHER
404219201
28
SHAFT, LID
370303511
29
DAMPER
404525001
30
LABEL
409612001
31
PANEL ASY, FRONT
409612101
32
C8089,CAP 470PF 2KV
110433211
None
C6043,CAP 0.22MF 250V
110470611
None
C6014,CAP 0.47MF 250V
110470811
None
C8124,CAP 8200PF 1.2KV
111764211
None
C6012-13,CAP 2200PF 250V
111989451
None
R148,RES 4.7 OHM 3W
121639711
None
R6015,RES 2.2M 1/2W
121977611
None
RESISTOR ASY HIGH VOL
122392534
None
VR8001,VAR. RES 2K
122562791
None
VR8002,VAR. RES 20K
122563091
None
SOCKET, CRT
125118211
None
T6004,TRANSFORMER STANDBY
143567511
None
T8004,TRANSFORMER LOT
143739921
None
T8003,TRANSFORMER HOT
143740121
None
T6001,TRANSFORMER PIT
143743611
None
L6001-2,TRANSFORMER
143747911
None
T8001,TRANSFORMER DFT
143770811
None
T8002,TRANSFORMER HDT
143773911
None
105,DEFLECTION YOKE
145153613
None
T8005,TRANSFORMER, FBT AS
145328551
None
REMOTE CONTROL
147686411
None
NL8001 LAMP,NEON
151777821
None
SPEAKER 6.6CM
152940341
None
PS1-3,IC LINK 0.6A 50V
153267900
None
PS8008,IC LINK 0.8A 50V
153268500
None
PS8001-7,IC LINK 3.15A 90
153359531
None
PS5001-2,IC LINK 5A 90V
153359731
None
S9201-12,SWITCH
157219811
None
F6001,FUSE 6.3A
157619311
None
PS701-2,IC LINK 2A 50V
157633621
None
RY6002-3,RELAY
175539511
None
59,SWITCH, RF ANTENNA
177178713
None
70,LEAD WIRE, H-V
177909551
None
AC CORD
179000112
None
TH8001,THERMISTOR
180019300
None
VD6001,VARISTOR
180107331
None
TH6002,POSITOR
180447521
None
SPEAKER 13CM
182552511
None
71,CONNECTOR ASY, MV
190026040
None
BATTERY COVER F/REMOTE
408188801
None
LENS DELTA260
408375001
None
OWNERS MANUAL
409460511
None
TUNER BTF-WA421
859859320
None
TUNER BTF-FA421
859859410
None
BLOCK ASY HVB-1031
859895532
None
IC501,IC DM-58
874901213
None
IC8001-2,IC STK392-560
874901908
None
PH6001,PHOTO COUPLER
874992435
None
IC5002,IC UPC393C
875910393
None
Recent comments
