sony tv kf50xbr800 i need help
bruno5001
hi all
ihave a sony-model# kf50xbr800.50inch wega
the lamp burn out.so i bought 1 on the internet.. the tv worked fine for about 3wks then 1 day the tv went to stand by. and about 10 seconds later it goes back on
now this happens ever 15 of 20 minutes.
please help
You have a bad lamp or the
You have a bad lamp or the lamp circuit, called the ballast circuit is bad. If you have no solid state repair experience, contact a pro to assist you in this repair. This is not a set you need to replace a simple board on. You need a service manual and the knowledge on how the circuit works. Good Luck
bruno5001
larry dillon
larry dillon
i bought the new lamp from-laptops for less,
3wks ago. so u think it's the circuit is bad or some thing else.please respond,
