We purchased a magnavox TV Model # 27MS4504/17 two years ago however we just got it out of the box and set it up yesterday, needless to say it is out of warranty. It turned on fine and was working for about 5 minutes. It then los sound and eventually the vertical hold on the picure was off also. We have un plugged and replugged in as well as re connected the antenna to no avail. Does anyone have any idaes about what is the problem or is this a repairable problem vs. replace the set problem?
You probably have bad capacitors in the power supply. I would say depending on how much the set cost, to have a pro have a look at it. Most sets now a days are throw aways. Good Luck
i bougth one of these tvsmodel number 27ms4504/17
and i was wondering if it gets digital tv because
i dont know anything about anything of these tvs
thank you
it the tv 27ms4504/17 a digital tv reciver or just analog
thank you
