STK394-250
5 posts / 0 new
rawan
STK394-250
Respected sir,
Is there equivalent for this STK,  Can i use STK392-560 INSTEAD OF STK394-250??
In india it is not available. This stk394-250 used in lg projection tv.
I dont have the data sheet of STK394-250
please reply.
regards
rawan
rawan
I have foung the best forum
I have foung the best forum for the technicians  and tv eng.
I am from india and in this field of repaiirng since last twenty years.
regards
rawan
No you cannot sub thos two IC
No you cannot sub thos two IC. Use another IC marked with the STK 394 and a higher type or rating. These STK ICs are nothing more then audio power amps that are used in many stereos. Good Luck
rawan
Larry Dillon said: No you
Larry Dillon said: No you cannot sub thos two IC. Use another IC marked with the STK 394 and a higher type or rating. These STK ICs are nothing more then audio power amps that are used in many stereos. Good Luck
Hi LARYY.
Its not  as stk used ina  amp.  , it is used in a  LG PROJECTION TV.  FOR CONVERGENCE.
REGARDS
RAWAN
I know that. I was only
I know that. I was only saying a point. Use from the same series.
