2603 posts / 0 new
moneyaz
Hey Larry can you forward me
Hey Larry can you forward me the service manual and repair docs so i can just dbl ck everything? Thanks again!      ps  is it a bad idea to leave the tv plugged in when i submerge it in the pool later?
dawizzard
Hello Larry,
Hello Larry,
I have the same blinking light problem on my Mitsu WS-65513.  It has been going on for over 6 months now.  It is driving me crazy.  Can you please send me the fix directions for this problem.  I would much appreciate this information.  My e-mail is: [email protected].
LLOYD
They are on their way Lloyd M
They are on their way Lloyd M. Good Luck with your repair!
Jeff Block
I just wanted to post and say thank you!  I am by no means an instrument guru and was able to complete the repair in about an hour and a half.  In fact, the last time I picked up a soldering iron was in high school about 15 years ago.  The TV now works better than the day I brought it home.
Thank you!
mheald11
like everyone else, i have a
like everyone else, i have a mitsubishi ws65513 that has been blinking at me for the last two days.  would really appriciate it if i could get a copy of the information required to solve this problem.  thanks a ton!
matt
moneyaz
me tooo Larry!!    Thanks
me tooo Larry!!    Thanks again, Mike       [email protected]
mhead and moneyaz, I will be
mhead and moneyaz, I will be sending the repair documents to you in a short while. Good Luck with the repair.
mike4949
Larry, I have the same issue
Larry, I have the same issue on my WS-55909.  Can you send me the instructions as well.
thx
Mike, I will have that
Mike, I will have that information out to you a little later this morning. Good Luck with your repair.
SPLAT
Larry Dillon said: If you are
Larry Dillon said: If you are handy, and can solder, you may be able to save about 700 bucks if not more. There is a very common problem with these Mitsubishi TV sets. There is a digital board inside these puppies called the DM board. A lot of times there are four capacitors that go bad inside of these TV sets. Sometimes, depending on how bad the capacitors are, and if the capacitors did not blow out anything else on the Dm board, you can simply replace these four capacitors and this will fix your TV set. The average that this works on is about 65 to 70 % of the sets can be repaired with this fix. The others are power supply issues or the DM board has other issues. If you would like to attempt to repair your TV set, I will send you the instructions on how to do so.  If you do not know how to solder well, do not attempt to replace the capacitors yourself. Pay a pro to do this for you. After all you are already saving a bundle of cash. Leave an e-mail address, and I will forward you the fix with and without the light engine. And if the capacitors inside the board are not swollen on the tops, as the direction shows you what they look like, change the capcitors anyway. I have had a few that looked good but the capacitors were on their way out. Good Luck
Hello there Larry,
Wow this is great news to me and I am so glad that you are willing to help all of us whom have this unfortunate problem. If you are still sending info I would be grateful for directions and information needed to repair the DM board in my Mits WS-55513.
SPLAT, I will send out the
SPLAT, I will send out the repair documents in a short while. Good Luck with the repair.
robertv
Larry, I have been waiting
Larry, I have been waiting since November for a DM board from Mits.  Could you send the instructions to me on how to replace the capacitors on my WS-65813?  It I am getting tired of staring at a blank screen.
Robert Vessey
WOW, I am surprised you did
WOW, I am surprised you did not repair the set already. I will certainly help you out and send out the factory service manual and the repair documents on the DM repair on this model of set. Good luck with your repair.
Catalina
Larry Dillon said: mhead and
Larry Dillon said: mhead and moneyaz, I will be sending the repair documents to you in a short while. Good Luck with the repair.
Like everyone else in this thread, I've encountered the blinking green light on my Mits WS73713... tried all the standard fixes, and am convinced after reading this board that I have the same capacitor problems as everyone else.  Could you send me a copy of the fix & part numbers needed from Radio Shack.  While I'm in there should I clean the mirrors or bulbs?
 Has Mits gotten back with anyone on weather or not they are going to reimburse people to have an authorized tech comes out & fix this major problem?
Don
No Don, It is past the
No Don, It is past the Mitsubishi warranty period. A warranty is a warranty. Why should it be extended as you agreed on the one year when you bought the TV set. Do NOT use the Radio Shack Capacitors as they will work but will not last as long and probably burn out the DM all together. Order the right high temp type caps as desribed in the repair documents. Good Luck with your repair.
rooster45
I to have found a blinking
I to have found a blinking green light would you send me the repair pages?
fen5bassman
Hey Larry,
Hey Larry,
I'm in the same sad boat as every one else watching the little flashy green light on my WD 62725  would you send me the instructions as well
fen5bassman at Yahoo dot com
SPLAT
After I posted my request for
After I posted my request for instructions I decided to look around and I located the unit and the bad caps...  Used some desoldering braid and now I am just waiting for my replacements so I can get back to business Laughing
Thanks dudeCool
fen and Dave, those repair
fen and Dave, those repair directions and the service manual should be to you by the time you get up this morning. Good luck with the repair.
prince666
rohauss said: hey larry my
rohauss said: hey larry my name is rob can i get a copy of those insturctions on how to replace the caps..... cause i have a WT-43211 and i have the crazy light... i replace the IC's and it did not work hopeing a capacitor on the power board but they dont look bad........ can u help me thanks [email protected]
Hi, I need the fix instructions bad, anybody has them please
email them to me at [email protected]. Many Thanks.
Prince what's the model
Prince what's the model number of your TV set and what is the symptom?
Chris0808
I own a Mitsubishi WD-62725 that I am having the same problems with.  Could you also forward the fix documents to me at [email protected].
 Thanks much,
Chris
Chris, on their way to you. I
Chris, on their way to you. I had to send in two parts. Good Luck with the repair!
mgordon
My friend just go her
My friend just go her mitsubishi 55 inch fixed. It had a constant blinking light and would not turn on. The guy said it was the computer so he replaced it and charged her 305. Was that a good deal or a rip off?
IF the computer was bad,
IF the computer was bad, those cost about  800 bucks, and you have to be authorized Mitsubishi to get one too. Although I cannot say for sure, but it sounds like he might have simply replace the 4 capacitors inside the computer or what we calkl the DM. That's about a buck twenty five for parts and $303.75 for labor. Nice deal for the tech.
JPMacDaddy
Hello,
Hello,
I have replaced the 4 capacitors and it still friggin blinks. I have not retraced my steps yet but will do so. I replaced the caps with NCE brand caps and a fan. Do I really need the high-temp ones if I have a fan? Will the TV work without the metal box around the DM board? Thanks again
No you need the metal box
No you need the metal box arounfd the set or you will get interference. Make darn sure that the DM is seated all the way down into the main board. The best way top tell is to take off the metal case with the plug out. Insert the board fully, and install the case.
david wood
Hello Larry. Thank you for
Hello Larry. Thank you for promptly sending the repair documents(ws-65513). About two weeks ago I replaced  the 4 capacitors I ordered from mouser. I did not install optional fanFrown. Everything seemed to go well and as I gathered a very anxious family around the set powered up!Smile Well it has worked fine for about two weeks until, out of no where the screen continually went blank and then came back on. We could still control the Dish network box and volume but no screen. Bummer. I was so pumped that it was working and now this. Well any ideas? Should I try retracing my steps or pull the DM board and reseat it. Or perhaps my soldering job was subpar? I'm not giving up! Thank You
Brass, did you have sound
Brass, did you have sound when the picture went out? After you unplug the TV set, does the green light stop flashing after a minute or so?
david wood
Larry, I did have sound. As a
Larry, I did have sound. As a matter of fact all regular functions worked just no screen. After I unplugged TV  the green light stops flashing after the minute. The screen goes on and off.????
Topic locked
