television
duradek
television
I have a 2002 panasonic 35" television set model # CT-35G25B the picture goes in and out when you walk across the floor the picture will sometimes go out but the sound is still there and if you hit the side of the tv or stomp on the floor the picture will come back something is loose inside i just can't figure out what
There is a bad solder
There is a bad solder connection in the video, high voltage, or the sweep power supply circuits.  It could also be on the CRT driver board as well.  If you have no solid state circuit board experience, play it safe and call in a tech to assist you in this repair.  If they insist on taking the set into the shop, tell them to forget it, as this should be able to be repaired in the home.  Good Luck, and let us know how this repair turns out for you.
PVP4U
where can i find a display of
where can i find a display of what those components look like in the tv?
