Toshiba TZ55V61 help
4 posts / 0 new
needs tv help
I have a Toshiba TZ55V61 projection tv and the place i put my cable wire from my cable box is loose and i don't know how to tighten it.  Also in the front where I put my video game wires in the yellow white and red input i have to push it in for about 5 minutes for it to the picture to work.
It sounds like the jack for
It sounds like the jack for the cable wire, and it is called an F type fitting, need to be replaced. Unfortunately, there is no easy way fro the novice end user to replace this without replacing the entire antenna block assembly.  I suggest you find an authorized Toshiba s repair shop to assist you in the replacement of this block, or connector.  if you try and mess with it, you inadvertently could be causing a severe shock hazard buy trying to replace the connector your self.  Now for the front video game jacks, it sounds like you are always plugging and unplugging and replugging in the video gaming system.  this will for sure ware out the jacks and the connections internally.  Not anything to do with this except find new jacks from the manufacturer and replace them  Good Luck, and let us all know how this all worked out for you and how you handled this problem.. Thanks!
funnyman6685
i have a toshiba tz55v61 and
i have a toshiba tz55v61 and the lenticular and frensel sheet both broke does any one know where i can buy another one of those so i can watch some tv
Marty Mudge
wakka said: i have a toshiba
wakka said: i have a toshiba tz55v61 and the lenticular and frensel sheet both broke does any one know where i can buy another one of those so i can watch some tv
i had mine fixed and i am selling it, but i live in Indiana
