TV problem
Evad
TV problem
I have a 32" Toshiba TV - it was purchased in 1994 - This morning the screen wet blank and showed just a red screen - the sound was still there.  I turned the set off and the turned it back on and everything was OK- In approximately 1 minute the TV shut off automatically- and now it won't turn on at all even trying the power button on the set.  HELP
41294
You have a problem with the
You have a problem with the CRT drive board, the RGB drive circuits, or worst case, the picture tube is going bad.  Without the proper tools and the service manual, this will be a difficult one to fix, as the voltages will need to be monitored for a period of time till the fault happens.  Good Luck and let us know if you have the set repaired.
